Your steps sound good.
As far as the o-ring locations go.....I just followed the a/c lines. Where ever there is a connection...there is an o-ring. Just be careful when disconnecting them. You dont want to twist the line. Make sure you use a wrench on both sides of the connection. one to hold it steady and the other to loosen the nut.
Good luck.
Good luck.
