When i start the car (15 or more minutes after i've been driving it) give it thirty seconds to throw some oil, then when i take off at about 2k rpm the motor loses power BAD and then strugles to get to 3k rpm(back fires, just sounds horrible) after 3k rpm it smoothes out. I've sat there and slowly gave the engine gas, then when it got to 2k rpms it would lose power, back fires and sounds like crap still applying more gas the engine jump to 4k rpm sounding normal and then goes away after 30-40 seconds, but all the time i drive the car it feels like it struggles (like nodding your head back and forth slightly) as i go through the gear to 5k rpm. wtf distributor, injectors, wire harness.
when i got the motor i put the following new parts on: dist. cap, rotor, wires, plugs even changed the fuel filter still aint helping. i sat next to the guy and watched him take the harness out of convoluted tubing and explain to me why he was adding and subtrating wires out of the harness.
so if you got any ideas on what is causing this, POST'EM.
