yes, i did search and what not.
the situations is, i had a REALLY tough time using the 3/8" ratchet on the bolt on. i d k what it is, people say and even the haynes say that a ratchet bolts directly to the drain plug? i don't even know if the bolt was the at bolt, but it sure felt like it and seemed like it.
i jacked the car up on passenger way up and even tried turned the wheels to the right and i was able to see the bolt, i tried the cresent ratchwrench and sears none would fit in w force. what's worse is, taking it out was super hard. because of an emergency i was not able to even do the flush. i had to force my way out again, the suspension was in the way,
right now, the bolt is not tight, just hand fitted. perhaps someone an give some suggstions or what not.
did both sides of the car need to go up? etc etc.
thanks..
thanks..
