my 90 accord transmission has been slippin out of gear for the past few days now and i think it might be low on transmission fluid and i went to check it but i dont see the dip stick for it i tought it was just me and i called my mom over cuz she knows alot about transmissions and such and she looked andshe didnt see it either maybe we were lookin in the wrong spot but someone tell me where the dipstick is thanks
cant find the automatic transmission dipstick ??
hmm well, imho
i'd buy about 7 quarts or whatever, and do a REFILL/DRAIN procedure. it's kind of like fill it to correct level, drain it in pan (not all) bout 2 quarts.
1) drain (don't drain EVERYTHING)
2) refill (tighten back bolt on and etc etc.)
3) move lever from P- D1
4) repeat steps 1 and 2.
ur supposed to do it in increments. im gonna do it, then drive it for like a week, then repeat it since after it heats up, it'll be better.
or u can warm up ur car a bit, but careful of hot flulidhahahahah
i usually undo the tranny hoses and put some clear lines on them and start the engine. i see which one spills the oil out and leave that in a bucket, and on the other one i put a funnel and start adding fluid, then i take the car thru all the gears. worked on my integra, never did it on my accord (and i used 9 quarts)
