i just received a 91 accord lx for free.. its a 2dr 5spd.. has 372k KM's on the odometer.. ill post a few pics of the engine bay in a sec.. im new to honda engines and was wondering if anyone could make a few suggestions on how to get this engine back up to par... very rusty and original clutch .. oil leak on the back side of the engine (firewall side) that i can locate buy cant find the EXACT leak point.. leaks near what looks like a rad hose.. there is also fluid leaking from the exhaust.. cant tell what it is by smelling of looking at it.. and when i turn on the engine it idles a little high till its warmed up (about 1k at cold start and goes down gradualy to about 650 / 700)
tune up suggestions..
http://www.angelfire.com/ct3/mo/Picture_029.jpg
gonnah have to save target as or open new window and paste... angelfire bad hosting.... if ne one knows better place to upload pics plz let me knoLast edited by 613lx; 06-11-2005, 11:53 PM.
The oil leak on the back-side of the engine is coming from the cam seal. Since Accord motors are tilted slightly to the rear, the cam seal leaks oil onto the waterpump boss and drips down the back of the block. The only way to fix this is to remove the drive belts, timing covers, timing belt, and cam gear to replace this seal. With that many kms, the timing belt and waterpump should probably be replaced anyway, especially if the belt is contaminated with oil. Other than that, I'd give it a good tune-up; flush all fluids, new spark plugs, wires, cap & rotor, PCV valve, and reset the igntion timing. It should run very well after all this is done. Also, since you mentioned that you are not very familiar with Honda motors here are a few common problem areas to look for....oil in the spark plug tubes, oil leaking from distributor, coolant leak at radiator, broken motor mounts etc. These are great cars and near-bullet proof engines as long as you take care of them.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
Originally posted by mrhondaThe oil leak on the back-side of the engine is coming from the cam seal. Since Accord motors are tilted slightly to the rear, the cam seal leaks oil onto the waterpump boss and drips down the back of the block. The only way to fix this is to remove the drive belts, timing covers, timing belt, and cam gear to replace this seal. With that many kms, the timing belt and waterpump should probably be replaced anyway, especially if the belt is contaminated with oil. Other than that, I'd give it a good tune-up; flush all fluids, new spark plugs, wires, cap & rotor, PCV valve, and reset the igntion timing. It should run very well after all this is done. Also, since you mentioned that you are not very familiar with Honda motors here are a few common problem areas to look for....oil in the spark plug tubes, oil leaking from distributor, coolant leak at radiator, broken motor mounts etc. These are great cars and near-bullet proof engines as long as you take care of them.
Originally posted by Blk EX Coupewhat side of the motor would the oil be leaking on? I started to notice oil leaking out of the backside of my motor recently and have had trouble locating it. Can you recommend anything else I should change as a precaution when I do my timing belt next week?
Timing belt replacement parts list....t-belt, balancer belt, waterpump, cam seal, crank seal, front balancer seal, front balancer seal retainer plate, rear balancer gear-drive o-ring, valve cover gasket kit, coolant, and drive belts.
Use ONLY OEM parts for everything, except maybe the outer drive belts and valve cover gasket kit....it doesn't really matter what brand you use for those.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
Fluid leaking from the exhaust????? Sounds kinda like a head gasket....not too sure though....also change out the fuel filter...another good tune up item.1991 Honda Accord Ex
Pics of the beast!
::::198.4 WHP and 146.6 WTQ Currently weighing in at 2700lbs...best time: 14.8@92mph::::
2003 BMW 330I Sport.....Daily Hustler....
Road Race #1
Totoro Squad #2
Do a compression test on the cylinders, (optional)
Check air filter of course
Do an EGR clean out. Chances are, they've never been cleaned. I'll link it to you. Click the smiley ---->
Also, and this is a cool trick, wipe the oil off the block completely. Then get some spray on foot powder and spray the back of the block. This will turn the back of it white and make it TERRIBLY easy to locate the leak point.Last edited by Masamune; 07-11-2005, 08:53 PM.Fix your Computer!
Originally posted by MikeWD, I'm a fanciful motherfucker. My ish is clean, quick, plush, mature and sophisticated.
ಠ_ರೃ
Originally posted by mrhondaIf you're under the car looking at the back of the block....if you see oil on the left side next to the timing cover then its the cam seal thats leaking.
Originally posted by Blk EX Coupethats where i'd figure the oil would be coming from...but it's on the back passenger side, so it's time to continue looking for the leak.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
Could it be the valve cover gasket leaking?
