I did try searching, didn't find the answers I'm looking for. When adjusting the timing, there are three marks on my flywheel. The main white mark and a line about 2mm above and another 2mm below the white mark. What exactly is 15 degrees BTDC? The white mark or the line above or below? Right now I have it set at exactly the white mark, but I want to make sure I don't have timing set for TDC cuz then it would be too advanced, right?
Timing questions
Originally posted by evol90accordI did try searching, didn't find the answers I'm looking for. When adjusting the timing, there are three marks on my flywheel. The main white mark and a line about 2mm above and another 2mm below the white mark. What exactly is 15 degrees BTDC? The white mark or the line above or below? Right now I have it set at exactly the white mark, but I want to make sure I don't have timing set for TDC cuz then it would be too advanced, right?Last edited by homegrown_xt; 06-10-2005, 03:30 PM.Can't complain, it was free!
Originally posted by evol90accordI just have a standard $20 timing light... it doesn't have any dials. The white mark is perfectly lined up in the groove and the engine seems to be running perfect now, I was just wondering if the white mark was 15 degrees BTDC. What do the other two marks mean then?Can't complain, it was free!
The red mark is 15 degrees advance, so you want to line it up with that. If you have an adjustable timing light and you set it at 15 advanced you should look for the white mark. But like I said, since you just have a standard non-adjustable light you need to line up the red mark.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
Originally posted by evol90accordThere isn't a red mark. Its just the white one with two little engraved marks above and below it. The white mark I thought was TDC, because when I did my timing belt everything else was lined up the way it should be when that mark was lined up...00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
god i wish i had a digital camera. I've seen pictures of exactly what your saying mrhonda and thats why i'm asking cuz mine doesnt look like that. It looks just like this (probably about this close together too):
-- <----white mark
the mark above and below the white mark are just engraved... no color. Its weird.
