Starter RELAY "WERE IS IT"
    an yall help me out because my car wont turn over with the key, but if i touch the starter with a wire from battery to the starter it will start
    so im thinking its my starter relay
    1990 Accord EX
    JDM 94 H22A
    i recently had the problem with the key not working. get under dash and look at clutch, there is a button on it, above that you will see a yellow connecter, pull that off and jump it and try your key, solved my problem
    also if that works, it will allow you to start in gear without clutch
    91 accord ex - white, 5 sp - stock (for now)
      thats an -ok- solution... BUT he will lose the ability to use cruise control. I have it jumped for my remote starter.
      Seattle Silver crew #5
      Member of the Midwest Car Club.
      ..........2004 accord ex v6 - J30A4.......................... 91 accord ex - JDM H22A -- Long gone...
        what do you mean jump it???
        1990 Accord EX
        JDM 94 H22A
          ttt
          1990 Accord EX
          JDM 94 H22A
            there are 2 wires that lead into a connector. unplug it and connect the 2 wires to each other, that should make the car think that the clutch is depressed.
            for the comment about losing the cruise control you could wire up a toggle switch from those 2 wires and mount it on the dash and "disengage" via switch, the clutch when needed.
            FA1
            355
              or if you have some cash you could spend like 40 dollars and get it replaced. Ask for the clutch switch at a parts store. if not, then jump the wire. I actually ran 2 wires in, one from the battery and one to the stator. on my 3g accord it used to have a switch for the antenna, but i didn't use it so i just stole that wire harness and hooked up the two wires to that. Worked for me.
              WTB:
              88-01 prelude 2.0si (3g) si (4g,5g)
              OR
              90-93 Accord.
              Has to be 5spd, has to be CHEAP. SUPER CHEAP. Will be in Indiana in February permanently and want a project car when I get settled in.
                thanks that worked
                1990 Accord EX
                JDM 94 H22A
