I need to buy the headers for my car but i have a f22b (jdm) single-cam vtec but i dont know if the headers for a 96-97 accord will fit or if it will fit in my cb7?
Need help for exhaust headers
Yes they will fit, they just have a second bung for the second O2 sensor since 96-97 is OBD-2.I live my life a quarter mile at a time. . . for those 56.7 seconds my Nike Shox are are laying the rubber to the asphalt. (Car to be born soon, should drop quarter times to about 15 secs or less SOHC all motor).
i always thought the jdm f22b is a non-vtec motor, single or dual cam. if you have a vtec head then it must be from a 5th gen right? if this is the case, then an EX header from a 94-97 should work. as far as the O2 sensor goes, if you have an LX you will need to extend the wiring down to the EX O2 bung location near the flexpipe. also since you'll be using a 5th gen header, it might not bolt onto the cat/mid pipe perfectly.
Originally posted by No1streetjusticThanx for the info so it should work properly even if the o2 sensor doesnt plug to the flange?what about the other sensor whole will it just be open ?
there is no JDM f22b1 my ricey friend. http://board.accordtuner.com/showthread.php?t=6215
the f22b1 is in my 97 Acura CL which is SOHC w/ VTEC, any 94-97 accord header will fit the f22b1 head you just need to find out yourself with whatever "JDM" motor you have if it is 4-2-1 or 4-1 which is just how the pipes come out of the head. Do some research, best place i've found is the link i have provided
ohhh and by the way, your welcome
Put a wideband O2 sensor in the open hole! Then hook an AFR gauge up to it and u b stylin!Originally posted by Junior SmurffNevermind guys, google search works wonders!
