Ok, I couldnt really find much about the timing of the motor, now i know its something that can be adjusted. But once you set the timing, is it basically set it and forget it or is it something that should be checked every 10,000 km for example?
Also, I tried to do an oil change, but the filter is hard to get at, any solutions to this?
