Oil light flashes for less than a second during startup. A longer flash when the engine is cold. I routinely check the oil, it has never dropped below the lower mark. It does not burn oil, but a leak is present around the valve cover gasket. Currenly due for an oil change (last change 5000 miles ago).
Possible dirty oil filter or oil pump issue?
180K and oil light never has flashed during while driving (knock on wood!)
