brake lights don't work
    My middle brake light and passenger brake light don't work and I tried changen the light but still don't work doe's anybody know what could be the problem thank you
    check and see if your cruise control work. if they don't work, then you have a bad brake pedal position switch.
      Yeah I think the cruz control works but my car is in the shop geting a new trans...
        check the switch under the dash, when you press the pedal it allows a little white button to move out, thats your brake switch.
        http://www.FLAccords.com
          If one of the lights works then its not that switch. It's going to be a relay if the bulbs aren't blown. A very simillar thing happened to mine and it ended up being the rear brake light relay, cost about 20 bucks to buy and I put it on.
          I live my life a quarter mile at a time. . . for those 56.7 seconds my Nike Shox are are laying the rubber to the asphalt. (Car to be born soon, should drop quarter times to about 15 secs or less SOHC all motor).
            Yeah only the driver side works and the rest don't do u know where the relay is located and how can I check if it good or bad thanx a lot 4 ur help
              i have the exact same problem. only the driver side works. im looking into it everyday and am still trying to figure this out.
              IN LOVING MEMORY OF GEORGE R. BRACEY. 3/2/83 - 7/21/05 WE WILL NEVER EVER FORGET YOU. HATED BY FEW, LOVED BY MANY. IT'S TOO BAD YOUR LIFE WAS TAKEN BY AN UNEXPERIENCED DRIVER. ALWAYS IN OUR HEARTS AND IN OUR MINDS MAY YOU REST IN PEACE.
                Had the same problem, check ur connection on the brake sensor in the passenger outer taillight, this controls ur third brake light and the passenger brake light. Sensor is hold by 2 screws inside the tail light take it out and check if any pins on the sensor or even the wire connector has burned out or what not. Most likely u have to replace the sensor or the wire connecter or it just came loose
                  i checked it out and it was the connecter it was burned so i got one from the junkyard 4 free
                    im having a lil dilema right now..
                    all my lights in my tailights luminate when i turn on the head lights, BUT none of them work when i step on the brake to switch to brake light mode..
                    and its wierd cuz my "check brake light" sensor doesnt read anything!
                    i need help asap!! dont wanna get pulled over for this bullshit..
                      hey how do i know what the white button looks like? where exactly is it at? help asap!!
                        okay i found it.. but how do i know it works or what not or if its faulty?
                        i changed all my lights.. double checked the harnesses.. still no stopping brake light!
                        i cant drive until its fixed! need help guys!!
                          Bump.. Please!
                            do you have a digital multimeter? there should be a few wires coming out of the switch, there is one that is green with a white stripe or white with green stripe i cant remember but that wire should read 0volts with the pedal at rest and 12volts when you push the pedal in. if it reads 0 when pushed well time to steal a switch from the junkyard.
                            FA1
                            355
