This forum is interesting. There are so many conflicting views on our A/C. Since Honda is a multi-million dollar company who claims responsiblity for desiging the A/C systems we are arguing about, it may be a good idea to reference this interesting TSB that was issued in the mid-90's discussing R-12 to R-134a conversion.
"Converting R-12 A/C Systems to R-134a"
(You need Adobe Acrobat to see it)
Anyways, there are some interesting points in the article.
First, it dispells the rumours on here that you have to replace anything except the high/low valves with 134 compliant ones (if the system is working properly and hasn't been opened to the atmosphere)
Second, if you have a 90-91, you may have to buy a new receiver line if yours is mounted on a "block" and points to the alternator because the new valves will not allow clearance for the equipment to connect.
Third, it instructs the techs to subtract 1 2/3 oz. of the systems R-12 capacity when filling with 134.
Fourth, the system appears to run at a higher pressure with R-134a refrigerant.
Here's some more information I've heard repeatedly from people who work on automotive A/C systems...
NO A/C system is "leakproof" They all leak to some degree. Over time, an A/C system (especially on a car) will leak enough refrigerant out to eventually need recharged. With this in mind, if your system is not in top-shape, installing 134 will not be a good idea because it runs at higher pressures in the system, and 134a molecules are in fact smaller than R-12.
If your R-12 system is just "not blowing as cold" I would seriously consider finding an older garage that still carries it and ask for a top-off. I went to a local shop, and the guy only charged me $40 a pound! Granted, not all people know the going rate for R-12 and it is indeed very expensive. It only needed a half-pound anyways. It's been two years and its worked great ever since.
