Will the H23 IM fit on the F22B head?
F22B head and H23 IM
Do you currently have a F22B and are determing the differences between the IM for the H23 and F22B? Or are you preforming a F22AX / F22B DOHC head swap? If you are putting together a head swap, then go with the H23 IM (if the F22B IM isn't available to you). The H23 and F22B IM's are identical. If you currently have the F22B engine, then switching to a H23 IM will give no benefits...
