well as you all know, my block is cracked, and im sure theres some water stirring around in the bottom. the car doesnt make any abnormal noises, but if for some reason the water fucked up the bearings and then also the crank/rods... can they be fixed?
im most worried about the crank. i can get new rods in no time, but id have to search for a h crank. im assuming i didnt spin a bearing, cause i would notice that... but if there is any wear on the journals can a crank polishing clean those up? when im looking for a block i wanna know if i need a complete or if i can reuse all my parts.
