That is the o2 sensor right? Well, im trying to remove it so I can remove the headshield from my exhaust manifold and it will not BUDGE. Does it unscrew? Pull straight out? I need some help
o2 sensor? wont come out
they unscrew, but they're on there pretty good. Use some liquid wrench to loosen it up.
Good luck, sometimes they're a real bitch. I know the one on my Nissan pickup was.Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
1985 Volvo 245 manual [IPD lowering springs, IPD sway bars, OEM Virgo wheels, 1977 quad round headlights, 1978 grill]
2001 Mazda B3000 SE 4x4 extended cab [stock except for CB radio]
2008 Ford Escape XLT [bone stock]
2015 Toyota Prius Three with solar roof [rear diffuser, Vision Cross wheels... cheaper than steelies!]
there is a special socket they make for removing the o2 sensor. I was also told its a hell of a lot easier to remove if you heat the engine up first, then dump a glass of room temp water on the sensor. I guess it makes the metal contract really fast on the sensor and its easier to remove... never tried it myself.
like 65 dollars, i took the heatshield off with out taking the o2 off. just force it, but dont brake anything plz...H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
