One of my radiator fans doesn't work on my 93 Accord LX 5 speed. The other one works but seems like its sort of slow.
Is there an easy way to fix the fan? Does the motor have brushes or anything I can replace instead of replacing the whole motor? If I have to replace the motor, where should I look? Junkyard? Parts counter?
Also today after running the A/C for the first time this season, the cooling system is acting up. I parked it, and began to get out, when I saw some smoke and smelled something burning. So I popped the hood and the smoke was coming from the coolant overflow bottle, and at the top of the bottle it was bubbling. I'm going to drain the fluid and refill it tomorrow, but is there anything I should be concerned about? WTF was that smoke? It diddnt smell like coolant. I thought someone was burning wood or something nearby, but it was my car. I diddnt get a chance to check the temp gauge before this happened, but after I opened the hood and saw all the smoke and what not, I turned the ignition back on to check the gauge and it read normal.
Hope you can help.
Hope you can help.
