Ok guys i also have a dodge neon and i have a problem with the suspension, i had some shitty ass coils on it, ever since i put them on my shocks bottom out it feels like. then went i changed them out with goldline sportline springs and kyb gr2 gas shocks they still bottom out what is the prob? any suggestions??????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????
Suspension problem!
Are the springs installed correctly? It may seem like a stupid question but it is amazing how something so simple could be the problem.
How low are you with those springs? Use the finger gap estimate and let us know. I don't know how different a susp. setup could be for this car vs. a cb7 but maybe, not positive, but maybe those shocks can't handle the spring rate or drop and are bottoming out. If that is the case, than you need better shocks especially since the shocks you mention are basically oem replacements and not truly performance oriented shocks. Either that or get springs that sit you higher."This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
FS Part out thread koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
