oil sensor
    oil sensor
    does anyone know if a oil sensor can leak oil??i have a 5 speed 91 sedan,wear is the oil sesor?and how hard is it to change,i think that is my oil leak because theres oil near/above the oil filter,but if the oil sensor was leaking would the oil light be on?i would rather have to replace the oil sensor and not the head gasket.
    the oil sensor is a round thing directly above the oil filter. if it is indeed leaking from there try first to take it out and clean the thread..then put it back in and see if the leak comes back....
    Retro!
    Hater
      thanks for the reply man,would you happen to know how much they go for and if its an easy job.thanks again.
        they should last, i say take it out and clean it....then put it back in...perhaps there is a o-ring on it that you can just replace...
        iono how much they cost...not many people buy those parts
        Retro!
        Hater
          i have looked around my engine and i cleaned it too but its hard to find the leak,problably is not the sensor if you have not heard of that before,its aroung the oil filter area,any ideas,could it be the head gasket?or ???????thanks for the reply
            if just cleaning it isn't enough...
            you could always try a little teflon tape on the threads...
            that's helped me out on a couple leaks I've had in the past...
            RIP Lifsatrip7
              well if its around the oil filter, perhaps the oil filter isnt tight enough...usually a leak you can see a line if its from up top..like for example your oil pressure sensor..there would be a leak comming from that down...if not then thats not it.
              if you see nothing comming from the top though then it may just be in that area...tighten the oil filter a little....clean around...drive and check again for leaks....
              if u use teflon....be careful not to let it come off haha..there is something called umm...its for threadded fittings....usually for air or gas lines....its like plummers glue...its blue...makes a nice seal
              Retro!
              Hater
                thanks for the reply's i will clean it again and start from there.thanks
