Cruise Control not working.
    It stopped working after I adjusted my clutch pedal engagement, the switch lights up and everything but the CC light in the dash doesn't light up. What could this be?
    You have been defeated by a car with child locks, how embarassing...
    "I noticed my f22 felt "healthier" until it blew up." <Myk>
    Oh crap, I think it is unplugged because I was messing with it earlier... Let me go check haha thanks!
      Nope that wasnt it I dont think, everything under there is plugged in. Where is the fuse located for the CC?
        check the vacuum hoses on the CC unit. mine doesnt work either. fuses are good, and the hoses are all hooked up, no light in the switch...i think mine is just fuXored.
        In memory of Jameel Johnson 4.30.05--You will never be forgotten...
        MY Car
        HydroDunk Mixtapes...check it out
          I checked them, they're all plugged in, it worked right before I messed with clutch engagement point.
            You might want to take a gander at the accel pedal and make sure the cable isn't binding or is at least still hooked up...since you were down there messing with the clutch pedal and that's when it stopped working...
            the only other things it could be are
            electrical... ie: fuse
            or
            Vacuum... ie: hoses
            RIP Lifsatrip7
              I checked the fuses and the vacuum hoses, that wasn't it. =(
