I got a door latch actuator for my car from the junkyard. How do i refurbish this one. Does grease particles get inside the gear mechanisms and need cleaning. The one on my car needs to be refurbished or the one i got from junkyard. SO i got one to test on and fuck up but was hoping for some direction from someone who has done this before.
Anyone know how to refurbish a door lock actuator?
I bought two once to fix Ruby. I cut one apart to determine how to release the failed on my driver door; then installed the second one (verified it worked first). That's one part I haven't attempted to "refurbish".90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
There's a spray dry lube made by 3 in 1 that I used on both of my cars' locks. When I first got my first 91 I thought the actuators were going out, as flicking the lock switch only resulted in an odd sound and a 50/50 chance the actual lock would move enough to unlock the door. They were all pretty stiff before I used it and now they turn back and forth easily. Getting the keys in and out now is a breeze. No more feeling like the key is getting hung up on tumblers.
Initially I thought it was just because my key was so worn, but getting a newly cut key only made it worse. The lube was the most effective fix for me. It would be a cheap easy fix if it worked for you.
This is what I used:
https://www.walmart.com/ip/WD40-1200...gaAiDrEALw_wcBMy '91 LX build. Bought September 2017. Sold June 2020.
http://www.cb7tuner.com/vbb/showthre...r /> t=209871
Current mileage: 399450 5/18/2020
My '92 LX build. Bought Novemeber 2019. http://www.cb7tuner.com/vbb/showthre...91#post3293791
Current mileage: 422679 11/21/19
Originally posted by wtfisafleek View PostThere's a spray dry lube made by 3 in 1 that I used on both of my cars' locks. When I first got my first 91 I thought the actuators were going out, as flicking the lock switch only resulted in an odd sound and a 50/50 chance the actual lock would move enough to unlock the door. They were all pretty stiff before I used it and now they turn back and forth easily. Getting the keys in and out now is a breeze. No more feeling like the key is getting hung up on tumblers.
