Oil in my spark plug tube
    Hey guys has anyone ever had this problem ? I was changing my plugs and wires yesterday and two of my plugs came out with oil on and around the threads of the spark plugs, what do I need to fix this problem? The car is been running great I just felt they needed to be changed. Give me some help here please! Thanks guys!
    search is your buddy:
    http://www.cb7tuner.com/vbb/showthre...ght=spark+tube
    Nitrous is like a hot chick with an STD. You know you wanna hit it, but your afraid of the consequences.
    My Member Thread
    ^ Updated pics 3/3/06
      i would replace your spark plug tube seals first befor replacing the rocker arm seals. go to the nearest honda dealer and buy it there. it dont cost much, maybe 3 bucks each. you sill need 4. just take off your valve cover and flip it around and you will see it right there. good luck.
        rocker arm seals?
        just hit up autozone or the like and get a whole valve cover gasket set.. its only like 15 bucks max and it has all the gaskets you need..
          yeah just get a new valve cover gasket..........thats the problem.
          Midwest car club
          Current rides:
          91 accord lx (5spd)
          92 accord lx (5spd)
          93 accord lx (auto )
            Are you sure you installed it all correctly? If you look in it there oil on the top? or is it comming in from the bottom. I would double check because if theres any leaks then that will be your problem
              There's four seals on top of the tubes, sometimes those need to be replaced, but that wouldn't allow oil onto the threads. Neither would the rocker arm seals(yes, they're real). So what you might have a problem with is blow-by, oil coming from around your pistons. I believe that's the problem I have, because I replaced all the seals when I installed my cam.
              -Jay
                i had this same problem, so i got some new spark plug cylinder seals and threw them in, and they still didnt fix it 100%, so i threw some of that orange sealant around them, put on my valve cover and presto, great fix ofr like 20 bucks, only prob is that if you ever need to take off ur valve cover after doing this it is going to cost you another 20 and so on! still will fix your problem tho...
                also, think the oil on the threads could just be from taking the spark plug out of the head and it being drug through the oil in the tube?? just an idea
                My baby laying down some power...
                http://www.youtube.com/watch?v=kd_Q8HSIyqA
                  Originally posted by Mista Juice
                  rocker arm seals?
                  your rocker arms got some o rings or rubber seals on the bottom of the rocker arms. i wouldn't replace it if you are not familiar with the rocker arms. just like a regular rubber o ring, it can get old and start to crack. not very common though.
                    My first comment is fizzbob's: HERE
                    My second comment is that everybody that has posted in this thread needs to read the original post in my DIY spark plug tube seal replacement HERE or just look in my signature to find it. I've had it in my sig since Summer 04, and it hasn't gone anywhere since then.
                    Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
                    1985 Volvo 245 manual [IPD lowering springs, IPD sway bars, OEM Virgo wheels, 1977 quad round headlights, 1978 grill]
                    2001 Mazda B3000 SE 4x4 extended cab [stock except for CB radio]
                    2008 Ford Escape XLT [bone stock]
                    2015 Toyota Prius Three with solar roof [rear diffuser, Vision Cross wheels... cheaper than steelies!]
                      i wasnt saying they dont exist, i simply meant that no one even mentioned anything about rocker arm seals..
                      and accordianate.. you actually made a diy on spark plug seals??.. hmm.. well i guess there ARE some people on this site that wouldnt be able to figure it out huh...
                        check accorddiante's diy man
                        I hate thieves!
                          Nope, this will NOT fix the problem. How many times do we have to go over this people....IT IS THE LOWER TUBE SEALS THAT LEAK!!! You have to pull off the rockershafts and replace the lower o-rings. ACCORDianate replaced the ones on his car last year and he made a very good DIY so everyone go check it out.
                          00 Jeep Grand Cherokee 4.7 V8 4X4
                          92 Honda Accord LX
                          95 Honda Civic CX
                            down sides for not replacing the seals?
                            I <3 G60.
                              The oil will destroy the spark plug wires. They swell up and split open causing severe missfires. Trust me, I've seen this alot.
                              92 Honda Accord LX
                              95 Honda Civic CX
