Ok so I've read and heard use the 94 and up accord procedure for timing and balancer shaft tension. I just took off my balancer belt and set the balance shafts correctly. Now i want to tension the belts. I see 3 procedure which are all different so am a bit confused. The differences are this
I only list starting after setting TDC
94 accord (f22b engine)
1. Loosen adjusting nut 2/3-1 turn
2. Rotate Crankshaft CCW 3 teeth on camshaft pulley.
3. Tighten Adjusting Nut
93 accord
1. Loosen adjusting nut 2/3-1 turn, then re-tighten it.
2. Rotate crankshaft CCW 3 teeth on camshaft pulley, then relooosen the adjusting nut to create tension on timing belt.
3. Tighten adjusting nut.
the third is similar to 93 accord.
I am going to follow the 94 accord one as honestly the other one doesn't make sense. I mean loose then tight then rotate then loose then tight. I hope this is right as it's a PITA to do it again. Anyone know for sure.
93 accord
