Hey have you guys ever experienced trans fluid leaking from the shifter
plate that has four 10mms that bolts to the trans case? It is the little plate
that the clutch fluid hose & slave cylinder clutch line bolts to.
I just found out mine was leaking from that area yesterday & was coming out
pretty bad.
I kinda googled around but didn't see much so I just went ahead & pulled that
plate off cleaned the area up, scraped off the tiny tiny tiny bit of sealant
that was only put around the bolts, & finally resealed it myself. I also added
a bit more of trans fluid to replace any that was lost.
I left it alone lastnight after I resealed it so I hope that it fixes the leak
because it was leaking all the way down the side of the trans where that huge
bolt on the side is. So that was how I kinda ruled out the axle seals. It was
also wet from trans fluid on the trans mount itself.
Any one experience this?
pretty bad.
