help with fuses!
    help with fuses!
    i have a 93 accord ex
    well i have no idea which fuses go in which hole inside of the fuse box under my steering wheel i need help and i have no service manual
    I'm alittle confused, but I'll try to help you. Do you have the fuse panel cover or are you missing it. It has a ref. sticker on the plastic cover. Also, you must be talking about the panel right next to the hood latch or dead pedal? Let us know and we can read them off to you, or try at least!
    Dan
    Also, did you mean owners manual? I don't have a service manual yet but wasn't sure if the service would have fuse info.
      yea its right on the fuse panel cover on the back side. if u dont have that im sure the diagram is online somewhere, finding it is gunna be the trick tho. if u cant do that go to honda and buy the cover and u will know where they go
