I am just curious as i got a chart for normal high side and low side port readings with ambient temperature. Here is link http://rechargeac.com/how-to/ac-system-pressure-chart. Does this apply to cb7's also. After i evacuate can i just charge freon in system till i get these readings?
What is normal high side and low side pressure readings for r134a
Originally posted by F22Chris View PostTurn the AC on high at the coldest setting and add refrigerant till you get within spec.
Do it slowly cause if you overfill the system, the AC won’t be that cold at idle and will get colder only when RPM is up.
Originally posted by F22Chris View PostYes and no. Low will cause lines to freeze and rapid compressor engagement/disengagement.
Too little and the refrigerant will not actually condense.
