I charged my ac a few weeks ago and the psi readings seem ok, they were low but ok. I am charging just on the low side and don't have one of those dual gauges that evacuates it and stuff. I have been waiting till the freon leaked out so i can put in this r134a with dye and see where my leaks are coming from. Today when i went out to check the readings it seems very high. WHen ac is off the psi on low side is at 70 psi about. WHen i turn the ac on i get 2 readings. The first is about 55 psi before compressor kicks on and when compressor kicks on it goes down to about 5 psi after a few seconds and stays there until compressor kicks off and then goes back up to 55 psi or higher. It seems it will climb even high if compressor stayed off longer. My readings a few weeks ago after i charged it were 35 when compressor off and goes to 10 psi when it cuts on. I have no ideal what this means. Anyone know? THe outside air temp today was about 67 degrees.
AC Question
When you get time, go to O’Advancenapazone and barrow a gauge set. If you’re using one of those gauges on the can of refrigerant, you’re not going anywhere. We need that high side reading too. At 67 degrees the low side should be around 40psi give or take a few pounds. The high side should be right around 150psi.
Both sides will move with the compressor turning on with some RPM so the drop in low side pressure is normal, but it should not be over 45psi
Originally posted by F22Chris View PostWhen you get time, go to O’Advancenapazone and barrow a gauge set. If you’re using one of those gauges on the can of refrigerant, you’re not going anywhere. We need that high side reading too. At 67 degrees the low side should be around 40psi give or take a few pounds. The high side should be right around 150psi.
Originally posted by F22Chris View PostPossibly too much. I can tell you for sure if I get that high side reading. Too full or a restriction somewhere in the system.
Also, always fill on the low pressure side when you get the gauges. Filling on the high pressure side is a no. You can hurt yourself.
connections to look for dye are compressor, condenser, accumulator, and evaporator. The evaporator will also have connections for the expansion valve and bulb.
Pressure switch is also known to leak just like the oil sender on the block does. Shine the black light on the entire condenser & evaporator to check for possible breaks in the windings. Hoses can corrode and cause pinhole leaks as well. To be 100% sure on the leaks you have to be 100% through in your inspection.
Service port shrader valves are like $0.50 so replacing those is very cheap and easy. Be sure not to crank them down as it’s easy to strip or break them.
Originally posted by F22Chris View PostOf it doesn’t reach 30inHG within a few minutes it means you have a massive leak in the system. Put some dye in the system and give it a small refrigerant charge. It’s going to leak out, but it will tell you where the leak is. Not the most environmentally friendly way, but it works.
