Weight of an f22 engine
    What does an f22 engine weigh with all but the exhaust on it? I'm going to buy an engine stand for that purpose and need to get the right one without over-spending.
    1991 Accord Lemons Race Car, "The Minnow" RIP
    1993 Accord Lemons Race Car, "SpaceEx Starship"
    Neuspeed Race Springs, Koni Sports, Acura CL Rear Sway Bar,
    Adj Upper Control Arms -3.0deg front, -2.0 deg rear
    M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
    Acura CL3.0 Brakes Front and Rear, Raybestos St43 Pads, Redline 600 Brake Fluid
    For what you're wanting to do, you can get the cheapest engine stand Harbor Freight sells. The engine is in the neighborhood of 400lbs when fully dressed. I think the one with four casters is a little nicer while not being much more expensive.
    Either way, Harbor Freight for something like this all day long.
      Yup. That's the plan. Just wasn't sure I could get the smallest one. Thanks.
        those things are usually designed for small block chevys and the like, and there's not much lighter than an all-aluminum 4cyl. you're good with just about anything.
          Yep, I have a 350, a 383, and a 2 bolt 400 sbc at home, all on harbor freight stands. They are tough.
          Under Construction​​​​​​​​
