oil pan bolt stuck
    oil pan bolt stuck
    grrrrr the thing wont move a inch i even used a impact wrench *sigh* Its wont move a fucking inch.....I used a hammer and all sorts of shit even a peice of pipe on the end of a wrench it wont move please help.
    Dynamic racing
    Look out for 4 point cb7 strut bars for dohc!!!
    bleh... i just put like 5 ounces of vodka in a 12 oz cup of mango iced tea...
    I know this is probably the stupidest question in the world, but are you sure you are going the right way? Double, Triple check because I do it all the time. Its not left handed threads so you should be good as far as that goes.
      im sayin. are u sure ur loosening it? other than that, if its in there that tight, ur threads are stripped anyhow....
      Finally Up and Running. Numbers to Follow. Check my MR
        left lose right tight
        i know lol
        Dynamic racing
          right but listen to me. when ur under the car. and the wrench is facing down u push or pull it towards the passenger side wheel.
            I got it i used a set of vise grips and a peice of pipe and a slegde hammer lol it was stripped real bad.....
            Dynamic racing
