Am about to order some sway bar links. Am pondering either mevotech or prothane. Or some other brand also if someone has a recommendation. Not moog though. My moog tie rod ends didn't last even a month on both sides.
Recommended top quality sway bar links?
Originally posted by zedjr10 View PostAm about to order some sway bar links. Am pondering either mevotech or prothane. Or some other brand also if someone has a recommendation. Not moog though. My moog tie rod ends didn't last even a month on both sides.......father in law has it back again. Time to shine
Originally posted by F22Chris View PostBe sure to grease them! Those will squeak like hell. Next time you buy Moog, grease the joint. They usually don’t come with any lubrication. If it comes with a zerk fitting, odds are you need to grease it.
I got some mevotech tie rod ends and one of them has a zerk fitting. I assumed it was pregreased but now i wonder. It's funny one has a zerk fitting and the other does not(passengers side has zerk). If it is fully greased should the ball joint be so easy to move around? I read lithium grease is best for ball joints and silicone grease best for bushings.Last edited by zedjr10; 04-17-2018, 12:46 AM.
Originally posted by F22Chris View PostThe joint should be able to move but to super easily. Once installed, just pump grease into the fitting till the boot swells up.
Yeah I wouldn’t trust that one personally. They shouldn’t be able to move with a fingers strength, but you should be able to move it with your whole hand. If there’s an option to be greased, I always do that option. I grease mine every other oil change. That might be over kill, but I’d rather push the dirt out before it gets a chance to do damage.
When you grease them, it WILL come out of the top of the boot. You want that to happen cause it’s getting the dirty grease out.
Originally posted by F22Chris View PostYeah I wouldn’t trust that one personally. They shouldn’t be able to move with a fingers strength, but you should be able to move it with your whole hand. If there’s an option to be greased, I always do that option. I grease mine every other oil change. That might be over kill, but I’d rather push the dirt out before it gets a chance to do damage.
