Hey cb7 tuners im having a little electrical problem with my car ok here we go this morning i go to turn on my car to warm it up as always when the car is warm and i turn it off i know the fan is suppose to stay on to cool off the car but on my car the fan will stay on until the battery is dead this happens to me every time i warm up the car so i just disconnect the battery so i won thave to jump start it everyday.need serius help ppl thx
Having problems with my cooling fan HELP!!
Originally posted by BluejaydeCan't help you out much(I suck at electrical stuff), but I can tell you to remove the fuse rather than disconnecting the battery. It's under the hood in the black box and it's labeled. That way you don't have to reset your clock and shit.I cheated on my cb7 with an e30.....Not cool. I will be a honda boy at heart though woop woop
Originally posted by fizzbob7is it still wired like an OEM setup or has someone fooled with it
maybe it's a faulty switch...i think there are two of them....follow the plug from the fan and the first one you run into is probably the culpritI cheated on my cb7 with an e30.....Not cool. I will be a honda boy at heart though woop woop
Guys i still need help with my cooling fan man i took my car to school the other day and when i came out of school i hear a cliking noise and i open my hood and the fan was running real slow so when i go to turn on the car it jus goes clik clik clik and the battery was gone.What could be the problem the fan works properly it turns on when it has to but it turns off when it kills my battery what could it be guys plz help me out.I cheated on my cb7 with an e30.....Not cool. I will be a honda boy at heart though woop woop
Im going to take them apart 2moro and im going to take some pics so you can see.But you want to know something else also soem times the fan does not turn on at all and when it doesnt turn on it last like 4 days like that but it turns on when you turn on the heat they both turn on welll idk if all cb7's do this but i know mine does.Should i get a new fan period.I cheated on my cb7 with an e30.....Not cool. I will be a honda boy at heart though woop woop
Thats the thing the heat can be off and it will turn on still but not as fast.The other day me and my father were trying to fix it and we wanted to see if the timing on the fan was correct we waited at least 10-15 min after the car was warm for it to turn on and it didnt even move.I thought it was the fan clutch but the fan wouldnt turn on at all if it was that.Im not trying to go to a junk and getting a new fan because if that fan is messed up alos i will lose my money.Is it easy to take off the fan?I cheated on my cb7 with an e30.....Not cool. I will be a honda boy at heart though woop woop
I am trying to tell you... the fan either works or it doesnt. If it spins.. then it works. If it never never never turns on.. then it might be broken.. then you just wire it directly to the battery for a second, and see if it turns on. I would suggest you just wire one or both to a switch by the dash so you can turn them on and off whenever. You can find a power source in the kickpanel fusebox, and that way, even if you leave the switch on, that fusebox *shouldnt* have power when the car is off.
