Ok so heres how it went down. Car was running great. Got crashed on the driver side while sitting in a parking lot. Car started up just fine and i drove it home. Due to the door not functioning i let it sit for a week or two without driving it. Jumped in it to start it anf would not fire.
Noted that i could not hear the fuel pump prime. Checked pressure at fuel rail and saw i had none.
Checked voltage at fuel pump and found none. Check #2 and #28 fuse, both good. I then assumed main relay went out. Bought new one and replaced.
Same result.
Tested old relay, it tests good.
Jumped wires at main relay connector, yellow and blue(always hot) with yellow(power to fuel pump) and fuel pump kicked on.
Using a test light put clip on the ground pin of the connesctor and the probe on the hot wire. Tested good.
When ignition is turned on the connector shows power at the black and yelloe wire.
I think thats everything.
Im wondering if my alarm has shorted out and is not allowing the car the fire. Just seems odd cause the relay should be getting power from 12 volt constatnt, and ignition source and has a ground.
If i just jump the fuel pump while turning the key it still doesnt fire, im guessing cause maybe the injector resistor boc isnt getting power?
Idk where to go from here.
The car has a hondata piggy back and i guess i need to hook up my computer and play around, but i really havr no idea hoe to operate all that .
Help!
Same result.
Help!
