front rotor replacement (bolt) question (1992 Accord EXR)
    I've got a question regarding the front rotor replacement on my 92 Accord EXR.
    After disconnecting the lower ball joint & pushing the axle through the hub and swinging the assembly out, there's these 4 bolts on the back that attach to the bearing/hub assembly.They aren't torx (tried that route). Are they "12 point"heads?(In the crappy manual I have they're regular bolt heads!!).Judging how tightly rusted in the other side was (I grinded the mothers off) I plan on installing bolts with regular heads anyway, just trying to save the hassle of popping off all the ball joints again on the other side if I don't have to.
    Does anyone have an idea of the socket type and size?
    Thanks alot!
    Canuk62
    i think its a 10 or 12mm 12 point socket.. as opposed to a 6 point socket.... when i did my rotors those little buggers scared the shit out of me
    dirty accord->
    http://www.cb7tuner.com/vbb/showthre...threadid=13407
    crappy website
      wtf?.. you simply need a 12pt socket.. go to sears and buy one and there ya go.. its not that big of an issue..
        it is a 10mm, 12 pt...
          thanks for confirming the size!
          OK,thanks alot. I'll pick some up & with some penetrating oil and some luck I should be able to get the buggers out his time.
          Take care.
