Just changed the thermostat and heater control valve that was leaking. I flushed the cooling system and refilled with fresh coolant. When my car gets up to temp (needle about half way) and only when the climate control knob is on cool, the coolant in the reservoir starts to steam and get hot. Anything i can check before i rule it out as a bad head gasket?
Coolant reservoir steams
I'm assuming you see no oil in the coolant and no coolant in the oil? Had you been losing coolant prior to the flush and refill?
Put proper mix of coolant in? Did you bleed the system (bleeder screw at the top of the thermostat housing)? I've found that raising the front of the car (12 inches or more if you can) allows you to get the system pretty full without having to run the engine. Fill the radiator, squeeze the upper hose to help push any air in it to the radiator. Once you have the radiator good and full, crack the bleeder until you get a solid stream of coolant trickling out. Close the bleeder, refill the radiator to the top, then install the cap.
If it was the head gasket leaking, it would leak all the time regardless of the position of the climate control. With the temperature on high (assuming the fan is on), the heater is removing heat from the coolant, but the thermostat should compensate by allowing a little less coolant to go to the radiator to maintain the system temperature.
If you didn't bleed the coolant, you may just be experiencing whatever air is in the system expanding as the system heats up and being pushed into the overflow tank.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
ok my rad is full of new 50/50 coolant, i made sure all old coolant and water was out of the system and had it raised like you said. so basically all i need to do is go raise the car back up and open that bleeder valve?
edit: coolant in oil.... No the oil is fine, under the cap and the dipstick is fresh, i changed the oil about a month ago, it was black but not milky. the steaming reservoir just started happening after the heater control valve started leaking.Last edited by accordlove; 08-17-2017, 11:38 PM.
Originally posted by Bunta View PostHow old is your radiator cap? If it is pushing hot coolant into the reservoir it may be due that. You have your cap tested to make sure it hold pressure.
it probably old af, i just bought this car for $350 it didnt even start lol has over 300k miles
Originally posted by accordlove View Postdo i boil it in a pot like the thermostat test?
it probably old af, i just bought this car for $350 it didnt even start lol has over 300k miles90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
