Hey guys,
I have a 90 EX-R that's been sitting for a few years (ran perfectly fine before) and am now unable to get it started. the Engine cranks but no start. was hoping to get some ideas on things to check. I'm not really a car guy so I have done most things I have read here and on google. some things are tough since I'm doing this alone.
EDIT: bought a used OEM distributor off ebay, just waiting for it to arrive.
pulled the distributor cap and cleaned contacts and ohm'ed the connections (measures correctly).
new battery, plugs & cables.
Cleaned grounds I was able to see.
checked all fuses in both locations.
checked pressure at fuel rail (seems to be none)
replaced fuel filter
roughly 10 liters of new gas
sprayed carb cleaner in the intake but I think since I'm alone this won't work. (no spark)
main relay was fixed 10 years ago and still seems to operate correctly on bench. correct voltage when tested.
bypassed main relay to force pump, still don't hear it and seems to be no pressure.
can't hear fuel pump but I'm doing this alone so hard to hear with the beeping when I prime it.
car is also on somewhat soft ground so hard to jack up and pull tank, but I'm really wanting to do this as a complete last resort.
no ECU codes showing up, but not sure if this would throw a code.
TCU codes thrown:
1: long blink (not sure what this is)
1: Faulty , Disconnected or shorted lock-up solenoid A
2: Faulty , Disconnected or shorted lock-up solenoid B
3: Disconnected throttle angle sensor
4: Speed Sensor
5: Console switch
7: Shift Solenoid A
8: Shift Solenoid B
Thanks for any suggestions/tips.
TCU codes thrown:
4: Speed Sensor
5: Console switch
7: Shift Solenoid A
8: Shift Solenoid B
