I have an easy question for some. I just took at my front upper control arm(first time). The 2 pivot joints that go into the body don't move(swivel). Aren't they suppose to? Did the previous owner install a set and torqued them too much. I thought proper torque was applied when installed so they don't move too easy but still move. Can someone enlighten me?
Are pivot joints suppose to move on Upper Control Arm when taken out?
Originally posted by zedjr10 View PostI have an easy question for some. I just took at my front upper control arm(first time). The 2 pivot joints that go into the body don't move(swivel). Aren't they suppose to? Did the previous owner install a set and torqued them too much. I thought proper torque was applied when installed so they don't move too easy but still move. Can someone enlighten me?==========================
1991 Accord Lemons Race Car, "The Minnow" RIP
1993 Accord Lemons Race Car, "SpaceEx Starship"
Neuspeed Race Springs, Koni Sports, Acura CL Rear Sway Bar,
Adj Upper Control Arms -3.0deg front, -2.0 deg rear
M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
Acura CL3.0 Brakes Front and Rear, Raybestos St43 Pads, Redline 600 Brake Fluid
If they are mounted in the car (without the upper ball joint attached) you can move the arm and it will be pretty stiff. If it doesn't move at all, that's a problem but that's unlikely.==========================
