F22A6 to H23A1 swap - EGR
    In the process of swapping my motor out. Found a local H23A1 that was too good of a deal to pass up.
    The EGR valves have different plugs on them. I haven't found any documentation on what to do with it.
    Are they electrically the same? Can I install the F22 one on the H23?
    1992 EX, 306,000 miles - Track toy - M2S4, H23A1, ST rear swaybar, Wagon brakes, GC coil sleeves, KYB AGX dampers, Stoptech pads, Toyo Proxes R1R, 2.25" exhaust
    Stock F22A6
    VIR, 5/22/2016: https://youtu.be/eR5-ylSPsxk
    H23A1 powered
    NCCAR, 9/4/2016: https://www.youtube.com/watch?v=TI5WpxGrEpE
    CMP, 10/16/2016: https://youtu.be/DOqoe5f-GLY
    Yes, just use the F22A6 valve on the H23A1. I'm assuming you're using your F22A6 wiring harness on this engine as well?
      Thanks. Yes I'm using the F22 harness. Swapped valves and should be good to go.
      Had to extend the distributor plug, run a knock sensor wire, and make a little adapter for the oil pressure switch (they are different connectors). Just got the motor into the car today, can't wait to fire her up.
      Stock F22A6
      H23A1 powered
