oem vs accel
    oem vs accel
    was wondering what your guys thoughts on oem vs accel is for cap/rotor/ignitor is and which you would go with, this isn't going on a stock motor its going on a built boosted motor
    http://www.ebay.com/itm/Accel-HST2-H...FW8oig&vxp=mtr
    vs oem
    OEM. Wires too.
      what about NGK? isnt NGK actually oem in japan?
        For the wires, oem is sumitomo. Not sure on the other stuff.
          i cant seem to find anywhere that sells the sumitomo wires
          but i did seem to find the cap and rotor
          http://www.amazon.com/OES-Genuine-se...+90+accord+cap
          but ngk wires should perform just as well right?
          http://www.amazon.com/NGK-HE57-Wire-...=sr_1_1&sr=8-1
            OEM is typically best but I have never had a problem with NGK or Denso parts. They are often the OE source anyway.
            1992 EX, 306,000 miles - Track toy - M2S4, H23A1, ST rear swaybar, Wagon brakes, GC coil sleeves, KYB AGX dampers, Stoptech pads, Toyo Proxes R1R, 2.25" exhaust
            Stock F22A6
            VIR, 5/22/2016: https://youtu.be/eR5-ylSPsxk
            H23A1 powered
            NCCAR, 9/4/2016: https://www.youtube.com/watch?v=TI5WpxGrEpE
            CMP, 10/16/2016: https://youtu.be/DOqoe5f-GLY
              The Accel coil is nothing to write home about. No noticeable difference over stock. Had 2 fail after just a couple of years and the build quality also isn't very good.
                NGK will perform just fine... but no, not as well as Sumitomo.
                I managed to find some Sumitomo wires via Google while on my phone earlier today.
                  this is what i was really wondering, is if it was worth "upgrading"
                    yea i couldnt find them i ended up ordering a set of NGK but i did stay with the OEM cap and rotor
