transmission seal
    transmission seal
    I am not sure of the name of the seal on the transmission that the cv shaft goes into. Anyone got an idea what it's called?
    i'm not sure if it's a input seal, output seal, or a main seal.
    The passenger side is dripping oil and needs replaced.
    CB7TUNER.com
    Educating each other one car at a time.
    Its called an axle seal
    sold! But here's my build thread for those interested.
    http://www.cb7tuner.com/vbb/showthread.php?t=206864
      Axle seal doesn't show up as a option when looking for seal under transmissions.
      nevermind i found it under axle seal thank you., just got to look under the right parts.
      CB7TUNER.com
        It pops out with a flathead screwdriver. On installation though use a piece of wood to gentle pop it in or you'll damage the new one they are fragile indeed.
          It's called an output shaft seal. Use a seal pry tool, and sure wood can work. I use a socket that's the correct size and gently tap them in.
            Output Seal: Usually where transaxles meet. Outputs the energy into the wheels.
            Input Seal: Where the engine meets the transmission. For example, like the torque converter seal. Takes power as input from engine. I've also seen trans pump seal here because our pumps are literally where the shaft is next to.
            Main Seal: There's usually the rear main or front main, usually a crank or oil seal.
            Selector Shaft: Where the shift latch goes. It does have a small seal which also should be taken into account if opening the trans and engine. It selects the gears basically.
