F22 throttle body on H22 upper plenum
    Will my stock F22A6 throttle body fit a H22 upper plenum + F22A6 lower plenum? I can get the upper plenum for $20 which sounds like a steal but i haven't found a throttle body for it yet.
    1992 EX, 306,000 miles - Track toy - M2S4, H23A1, ST rear swaybar, Wagon brakes, GC coil sleeves, KYB AGX dampers, Stoptech pads, Toyo Proxes R1R, 2.25" exhaust
    Stock F22A6
    VIR, 5/22/2016: https://youtu.be/eR5-ylSPsxk
    H23A1 powered
    NCCAR, 9/4/2016: https://www.youtube.com/watch?v=TI5WpxGrEpE
    CMP, 10/16/2016: https://youtu.be/DOqoe5f-GLY
    B,D,F,H are interchangeable as far as bolt pattern.
    not sure why you would want to put the small throttle body on the bigger upper plenum.
    CB7TUNER.com
    Educating each other one car at a time.
      Wouldn't there be some benefit to the larger upper plenum even with the stock TB?
      Stock F22A6
      H23A1 powered
        The early F-series throttle bodies like the F22A/F20A have a different pattern than the later throttle bodies that were similar to all of the other Honda offerings. If you wanted to retain the throttle body size with the plenum upgrade. You could go buy one off of an F22B1/2 from a '94-'95 Accord. Or, if you wanted to ditch your FITV, you could buy an aftermarket one and get a size increase as well.
          sorry about the misinformation, my spare throttle body must be from a f22b
          CB7TUNER.com
            masospaghetti, if you can get the plenum for $20, do it. Then you can pick up a throttle body later, when you find a good deal.
              Alright, i'm going after it. Just got a H23 TB on eBay for $39.
              Stock F22A6
              H23A1 powered
                You're gonna love this mod. It makes the F22A6 worth taking to the fuel cutoff.
                Originally posted by lordoja
