Car turns over fine (starter engages) but takes a long time to start when it's completely cold. It will restart easily once its started the first time. I've done the standard tune up items (fuel filter, spark plugs, timing belt).
Also the car bogs down under WOT. It has more power on part throttle than it does in WOT.
My guess is a fuel delivery problem or clogged cat because a bad sensor would give a check engine light. I don't have a check engine light. Am I on the right track here? I figured next step would be to check fuel pressure and drop the cat. Thanks all.
