93 honda accord SE, 327K miles. ABS light has been on for at least 10 years. Replaced original master cylinder almost a year ago, and within the last 3-4 months, I've been losing brake fluid to the point of it being almost empty every 1-2 weeks, depending on how hard I've had to brake.
Took it back to Pep boys last week (who did the original replacement) and they said it was the ABS reservoir leaking but couldn't find any other brake fluid leaks. They put some dye in the ABS reservoir and judging from stains on the concrete, it is clearly leaking on the passenger side (I'll see if I can get a picture).
Can an ABS reservoir leak cause a leak or loss of regular brake fluid, or should I have them look at something else?
