Short:
I feel as though my cb9 isn't making the amount of power it should. If i had to guess I would say a little over half it's normal horse power. The vehicle makes a stuttering sound when accelerating. If normal acceleration between gears made a "vroooooooom" sound , mine makes a "vr vr vr vr vr vr vr vroooom" sound. Idle sounds fine , starts fine , cruising at a set speed is fine. My 100% guesses are fuel filter/injectors/spark plugs/wires/cap/rotor? None have been changed in 4 years and 38k.
Someone also mentioned to check the timing which I've never done on any car.
I watched a Motorweek episode of a 91 wagon and when they tested it in stock configuration it did 0-60 in under 9 seconds. Mine is very much nowhere near that , If i floored it maybe 15. If I stayed under 3000rpm about 30.
Extra:
It feels as if the car is very heavy , which would make sense if the engine was down on power because it's power to weight ratio would be worse and therefore heavier.
I feel the engine works very hard just to keep up with traffic. A simple stop light and every other car just takes off. I don't want to floor it everywhere I want the car to last , it's not a tuner or racer of any kind all stock.
When I had a 4 door 1990 ex manual , it was really quick. My mom got pulled over in it accidentally doing 80 and she didn't even notice. The wagon is heavier and the auto transmission is geared lower but surly there's something wrong with it.
Extra:
