Barely passed smog (test only) in CA
    HC(PPM) Max, Ave, Meas
    15 mph-116,31,76
    25 mph-91-20-41
    CO(%)
    15 mph-.74,.1,.74
    25 mph-.62,.09,.59
    NO(PPM)
    15 mph-791,237,551
    25 mph-730,199,215
    As you can see ...it barely passed in CO(%).....
    replaced oxygen sensor already...get goo gas mileage (28-30 mpg)
    could it be the catylic converter???
    Thanks
    I failed my smog test then a week later i went and took it again but i was told this time to go run the car hard and make sure the cat is nice and hot then it sould lower your emiisions alot. I passed mine with flying colors the second time
    My Ride
    myspace
      I drove from LA to westminster (35 miles)....is that enough?
        could be the catalytic convertor...but worry about it in 2 years
        btw, im in l.a. too, close to downtown...where you located?
        Originally posted by fizzbob7
        Originally posted by ACC0RD22
        So. Cal OUTLAWZ
          in vt, 94 cars and lower dont have to pass an emissions test...
          Audi A4 2.8 Quattro Sport
            Are you sure it's the catalytic????I know I dont have to worry for another 2 years....but I like to have it replaced soon.....if I know it's the problem...
            I'm in Rosemead....san gabriel valley
              if you have an aftermarket header, they usually tend to wear out the cat prematurely. this could be your problem. you should look at the cat in general. is your timing off? are all your vac lines in place or in good condition?
              1cor10:31
              - 92 LX coupe
              - 96 EX wagon (sold)
                Have the EGR ports ever been cleaned? This is the most common cause of failed (or close to it) emissions test. If they have never been done, try that, your car will run alot better too.
                00 Jeep Grand Cherokee 4.7 V8 4X4
                92 Honda Accord LX
                95 Honda Civic CX
                  My car is all stocked...no mods....no i have never cleaned the egr ports..
                  the car is running very smooth...nothing is wrong...but I just want to get ready for the next smog check...
                  what should i do ....clean egr port..then what....replace the cat?
                    Just clean the EGR ports and give it a good tune-up and you should be fine. Cat failures are not very common on these cars.
                    92 Honda Accord LX
                    95 Honda Civic CX
                      thanks for the advice...i'll clean the egr ports ...also picked up
                      2 bottles of seafoam....I'm gonna give it a try
                        I think there is a DIY for port cleaning around here somewhere if you've never done it before.
                        92 Honda Accord LX
                        95 Honda Civic CX
                          yea, i might be due for a EGR one soon since it barely passed last year...
                          I <3 G60.
                            thats more on the levels of NoX...but its a good idea to do so.
                            but i think its the cat.
                            Retro!
                            Hater
                              So you think it's the cat???
                              what's the cheapest way to replace the cat and makes it legal for smog?
