2 Questions...
    2 Questions...
    1) Im looking to replace my short ram filter with a k&n filter with same diameter but maybe a few more inches in length, i think this would work nicely, anyone have any product # ?
    2) Does a full coilover kit such as Tein need a camber kit? I would think so but just double checking. I appreciate the help as always.
    1. do you mean that you want a longer cone?
    2. yes, it will still need a camber kit.
      1)I don't have any part numbers off hand but any auto store can do a reverse look up using the dimensions you supply. That's what I did when I ordered my cone K&N filter.
      2)With coilovers, it just depends on how low you set it. I think the Tein ss drop the front between 1.4-3.3" and the rears 0.7-2.5". The general rule of thumb is any drop over 1.5 inch should get the camber corrected. So if you ride at max height, you won't need it while full drop will definelty require one.
        thanks guys...well yeah i just wanted a longer cone so theres more volume of air inside the filter and piping. I was just wondering if anyone had any numbers off hand.
