Hello recently on my 90 the antenna stopped going up. It will go up very little when turned on and try to continue to go up you can hear it clunking til it's fully open but it doesn't fully open and it won't close on it's own. Basically I need to find out if I can permanently set it open, how to change it or what I should do for a new one.
Antenna Stopped Working
what has happened is your motor is still good but.... the rod is connected via a toothed plastic line that the motor moves up and down... over years and rain water and such probably help it gets brittle and sometimes breaks... you can do two options ... If your like me and rarely to never use the radio take it out and block off the hole... or you can get replacement Mass from ebay and repair it using that and electrical grease.... http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.T RC0.H0.X90%2F93+honda+accord+power+antenna&_nkw=90 %2F93+honda+accord+power+antenna&_sacat=0
Originally posted by evil_demon_01Do it once, do it right.
Saving a dollar is not worth risking a life.
White -91 LX Sedan - leather converted
Mulberry 91 EX Sedan
The project 92
Lol yes! Mine worked for the past 3 years or so all the other cb7's antenna's work too. Thanks Schier is there any DIY on replacing the antenna? If I can just get it to get stuck in the up position for a while because as cold as it is outside right now do I really wanna change it? NO lol. I do use the radio a bit mostly aux though.Last edited by Kev1990; 01-16-2015, 11:24 AM.
Our proceedure is basically the same as in this video
Also check out
INT: power antenna cleaning
http://www.cb7tuner.com/vbb/showthread.php?t=166674
Originally posted by Flip-Eye View PostWait, are you trying to say you had a CB7 with a WORKING power antenna?
I've never heard of such a thing
Originally posted by Kev1990 View PostWell I can pull it up all the way but there's no resistance and it slides right back down lol. So assuming the motor or what-ever stopped partway up.
If it drops back down, it means the plastic drive belt inside has broken. Repair will require that the antenna be removed and opened up to remove the broken pieces of the drive belt. While you're in there, it should be cleaned and relubricated. There is a pin that holds the belt against the drive gear; this wears so that it doesn't hold the belt well - it can be rotated to hold the belt against the gear again. There used to be a DIY on how to rebuild them. If you buy a mast, get it from Bridgewood Motorsports (Antenna Masts R Us on e bay). For a price, send it to me and I'll rebuild it.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
I got a mast for 17.99 shipped from this place. Installed it on my new DD and it works great! goes down all the way and i've got good radio reception now.
http://www.antennamastsrus.com/Honda...01990-1993.htm
member's ride thread
91 Accord SE 176k
Originally posted by Losiracer2 View PostI got a mast for 17.99 shipped from this place. Installed it on my new DD and it works great! goes down all the way and i've got good radio reception now.
http://www.antennamastsrus.com/Honda...01990-1993.htm90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostSame place I mentioned. You got a new fender nut and grommet, correct? Did you have to take your motor apart to get any of the old one out? I did some searching; looks like an opportunity for a DIY - I didn't see one that deals with completely rebuilding one.
It didn't come with a nut. I had to reuse mine.
Its not the greatest design, mainly my gripe is it doesn't have an angled end piece to make it easier to feed at first, so it take a couple tries to get it to accept the new mast's plastic teeth. Lubricating the internals with white lithium grease also helps with it going into the coiled housing.
but for under 20 bucks i now have a fully operational antenna mast. I remember buying one from the dealer 8 yrs ago for 75 bucks.
91 Accord SE 176k
