What's up guys. Just had this issue today with my accord. I was driving about 50, noticed my gauges started bouncing up and down, and all of a sudden the car stalled. Tried to start it again and it starts but dies immediately. If I give it gas it will run for like 3 seconds then shut down again. When i turn the key to the "on" position, I'm getting no lights or anything on the dash, only when i try to start the car do I get dash lights. Radio heat and everything else works. Battery is fairly new and alternator was replaced. Also did a full time up when I got the car, plugs wires Spark plug tube seals, rotor and cap. Any idea what could be causing this. I need to get this running ASAP since its my winter car. Also forgot to add that the fuel pump DOES prime
When I turn the key.
Thanks!
Thanks!
