gates performance belts
    You don't want the tensioner to have any more or less tension than the oem unit, so I would recommend the oem one. You're getting a fairly expensive belt why not get the oem components?
    I went to majestic honda for my parts
    YouTube Clicky!!
      Gates is 50 or 60 bucks and suppose last longer than oem with its kevlar made material and it won't stretech
        What I need? Belt, tensinor, tensior spring, balance shaft belt and seal, and imma change the crank seal also.
          Cam, crank and balance shaft seals are all right there, might as well change them out.
          I forgot how much those tensioners cost, wow.
          Springs are cheap.
          That's pretty much it, water pump and liquid gasket material, too.
          YouTube Clicky!!
