is this the correct wiring ?!
    [IMG] [/IMG]
    If it's just a solenoid, then there isn't a wrong way to hook it up. Same reason you can't hook a relay coil up "backwards"
    YouTube Clicky!!
      it'll still purge anyways even if you interchange the wires ?
        Yes sir. Again as long as it's just a solenoid.
        You could hook it up to the battery and should here a click which ever way you have the wires.
        YouTube Clicky!!
          thank you sonica !! I just wanted to be sure if it is purging because I recently cleaned my fuel tank and my pump strainer and changed my fuel filter but wasn't sure of the two-way valve and evap mechanism
