alright maybe I did something stupid but I seriously need help. Recently I have fixed my A/C system by going to an A/C shop as I lack the tools.
so here's how things are now that can't be changed anytime soon because of money issues.
the shop changed the A/C connections because they had leaks, also my compressor was dead so they changed it, however, they have installed a compressor from an F22B !! compared to the original dead one, it has a smaller radius but a thicker Pulley of 6PK, but they told me only the length of the belt matter, it is ok to put a 4pk as long as it is tight and so they did.
A/C works but car shakes like crazy and idle dips like crazy. Did I install the wrong compressor ?! yes or no ?
After going for a period of 10 minutes then hitting the brakes when reaching traffic, the engine idle suddenly stutters violently and the car shuts off, 3 red lights are on the dash
I have to put the key on the off position then start the car again. I checked my dip stick and no oil appears on it ... is my engine fully empty of oil ?
by the way it is been a year I haven't changed my oil, it leaks and I add, this time I didn't add so my dip stick didn't show any oil ...
should I just add a quart or change oil and filter all together ... should I check the oil pump and clean it ?
don't ignore this thread please
