Hello guys.....i need some help.....my oil light turned on and there is no leaks or anything.....the dipstick oil reads at the second little hole..... .....and there is the slightest knocking sound ......i just got the h22 like 3 weeks ago and now im scared.....what do you all think!?!?!
help with oil issue!!
Originally posted by fizzbob7if you're sure the oil level is fine, make sure the little plug is connected to the sensor above the oil filter (oil sending unit)
the knocking may be something different.....if it's truly knocking, you're fucked anywaycb7 A NEW ERA
Make sure your oil pressure switch above the oil filter is ok. In fact, go ahead and replace it to be on the safe side. Its around $30 or so for the switch and it takes less than 30 mins to switch the switch.Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
